Where is the best price under $1200?
lovinthehd Audioholic Jedi Apr 26, 2018 #2 Haven't boticed an Amazon app on an avr...many have Pandora. I recently bought an Amazon Fire Stick as my Onkyo stopped supporting Spotify and my Denon 4520 had issues until recently until they did a firmware update to Spotify Connect.
j_garcia Audioholic Jedi Apr 26, 2018 #3 Yep, Fire stick would be the cheapest and easiest way to do this IMO. Someone here confirmed that the stick works when plugged directly into the AVR. You won't find the Amazon app on any AVR as far as I know.
Good4it Audioholic Chief Apr 26, 2018 #4 Thanks guys.Just saw that Denon AVRX4400H does. Last edited: Apr 27, 2018
S snakeeyes Audioholic Ninja Apr 27, 2018 #5 Yamaha supports Pandora and Spotify. Pandora Plus is only $5/mo and much better than the Amazon Music app. I don’t bother with the Amazon app anymore. I do send YouTube music sometimes over AirPlay from my iPhone though. Or Bluetooth also works. You can do the same with the Amazon app over AirPlay or Bluetooth. I have the 2060 Yamaha in my theater and the 681 in my bedroom.
rom3 Audioholic Intern Apr 29, 2018 #6 Good4it said: Thanks guys.Just saw that Denon AVRX4400H does. Click to expand... I just got the Denon X4400H, and although it does technically support Amazon music, it is through the HEOS app on a phone/tablet not built into the receiver, and as far as I can tell, one can only play Amazon's pre-selected play lists, not your own music or play lists, so check into the details.
