What am I looking for spec-wise?
F
fraxturepoint
So my Onkyo 609 seems to have died, never quite seemed right. I'm looking for a good AVR that has bluetooth (easy spec to spot), but also for a zone 2 out that doesn't use the 7th channel up. Are 9.1 systems the only ones that can run 7.1 media rooms, and a second powered zone without screwing up the back surrounds? My Onkyo couldn't run the full 7.1 when I had powered zone 2 turned on.
Trying to stay affordable, 500-600 street price?
Thanks
crossedover
crossedover
If you want 7.1 and powered zone two yes 9.x is the only all in one solution and your budget doesn't allow for that. Maybe consider a refurbished 7.x and a cheap amp to power the second zone.
afterlife2
afterlife2
Thanks
If it's a HDMI issue they will fix it for free. Contact Onkyo before you do anything.
F
fraxturepoint
Thanks, good info from all. I'm not too afraid of the refurb stuff, probably gets better attention while repairing it than some of the new stuff off the line. I'm gonna probaby send the AVR in to Onkyo anyways, and plan for a future upgrade to a 9.1
I'm not running anything crazy on zone 2, just a pair of yamaha outdoor speakers, 5 1/2's I think.
