What about the Wharfedales?
O
Orpheus
<font color='#000000'>I just found this forum today, and I must say, I'm incredibly impressed with the knowledge base here!  With that in mind, I have a question.
Recently, I've found myself in the market for a brand new speaker setup, and I think I've managed to narrow my choices down to two package deals that seem to fit my budget, but I'm completely unfamiliar with either brand I'm looking at...  So basically I'm relying on reviews and specs on the internet.  Is anyone familiar with either the Wharfedale Moviestar Diamond 800 Package (including 2 pair of Diamond 8.1 bookshelves, and a Diamond 8 Center, and which I've been able to find for about $550) or the Acoustic Research HC6 Package (which includes 4 satellites, a center and a sub as well, and I've found for around 400)?
Both packages are pretty similarly priced, and seeing as I already have a pretty nice Yamaha YST-SW205 subwoofer connected to an older Yamaha RX-V495 receiver, I don't think I need a package with a Sub...  So I was already leaning toward the Wharfedales.  Anyway, having a modest budget (I'm looking to stay within the $600 range for a 4 sat + center setup) I feel like I'm drowning in choices, and I don't think I can tell the pretty-good from the not-so-good...  Does anyone have any advice for a wide eyed, gape-mouthed neophyte with champagne tastes and a beer budget?  Particularly, does anyone have any experience with either of the products I've mentioned?
Thanks for any help you can give!!!</font>
pemike1973
pemike1973
Hi, I´ve got a Wahrfedale 8.4 and 8.2 in a 6.1 configuration and tyhe only negative draw back is that these speakers require A LOT of amp power, I´ve got a Yammy pushing out 95w/ch and I honestly think that I could do with a little more power.
Other than that, they sound GREAT, good bass and clear sound. I enjoy ACTION dvds and listen to reggae and rock music, no complaints with this either.
Hope it helps.
kay
kay
As said, they do need lots of power. Also they have a smooth sound, not very exciting but if you use it with matching equipment they are unbeatable for the money.
conchyjoe
The ARs also sound as good as or better than the Wharfdales and although that configuration is a couple years old, they do sound terrific; that is of course in the context of the cost. Wharfdale's also decent, but that's about it IMHO...
Cheers :cool:
Rock&Roll Ninja
Rock&Roll Ninja
Didn't the Diamond 8's get replaced by the 9's this year?
