Funny you should mention this...
http://cgi.audioasylum.com/systems/1606.html
When I got my setup from AudioAdvisor in '02 (and paid full price
) I had the chance to try them at home and also try some of the price comprable brands avaliable locally. My initial testing was for only the front main pair and mainly using music as the main test. I'm of the firm belief that if these speakers do the trick, particularly on music, their mates will also.
This included Polk, Infinity, JBL, PSB and Paradigm. Yes, I compared florstanders to bookshelves and the whole bit but since I was working within a price point, fair is fair. This is one advantage to local buying and a credit card. You can do this sort of stuff.
You can see what I wound up with. I went with the F1's not so much because of the price differential of the F2's ($200 then) but since I knew I would be implementing a sub, the second woofer on the F2 was redundant. It was a good guess. From what I can hear in my home, the F2 may have rendered the system a bit mid bass heavy.
As far as the sub, unless you get a really, really good deal I think that can get better price/performance from other subs. (SVS, HSU, Adiere,etc...)
One caveat... When I bought my stuff, the dipolar (or bipolar) R1 was not available. Had it been, I would have considered it since my system's main goal is HT. If music is your main gig, then the B2's are excellent since music works best with a monopole design. ...just a thought
To this day, three years later, I still don't regret it and haven't heard anything that would fit in my room to make me want to change.
Basically, it's all a matter of taste, preference and $$. For me, this hit the bullseye, even at full price. Remember, I may have paid full price three years ago but by the same token, I've been enjoying them for three years already.
