What’s the difference between a furman elite 15 pfi and the 20 pfi?
tbwebdev34
I’m looking to buy a power conditioner by furman for my 7012/1582mk2 x2/1585 set up and trying to figure out if I would benefit from the 20pfi....it’s 800$ more do idk if it’s worth paying up.
IIRC, it's the amount of current it will handle, which means you would also need it to be on a 20 Amp circuit. If you don't need or have that, you don't need the 20PFi.
panteragstk
panteragstk
Ah so a 15 would be fine then I’m guessing
Unless you have horrible power that adds a lot of noise to your system, you'd be much better off getting an APC power conditioner with UPS. The UPS will do quite a lot to save your gear. That and most of the models have voltage regulation as well. I have one and it's great since we have random brown outs during storms. Not as bad as my last house, but enough that it's necessary.
tbwebdev34
I have a panamax for my tv oppo and etc wanted another good unit for the audio side of things, that’s why I cane up with these two models after reading around the web
tbwebdev34
Is the furman not a good unit or, I’ve heard good things about them compared to panamax
