Weird problem with Video Essentials calibration
V
Vaughan Odendaa
Hi there,
I recently attempted to calibrate a projector, the Panasonic AE 900. I went from test to test. No problem.
I then carried on to the sharpness test. I left the screen on for about a minute without doing a thing. I was distracted. When I looked at the screen, I noticed that the whole projector screen was bright white.
I was currently using HDMI, and after switching back and forth between inputs, I found that the HDMI was just bright white. I turned the projector off and five minutes later turned it back on. Same problem.
It's since been two days and I haven't checked to see what the results are. The S-Video inputs are fine right now. But this worries me. If I must do another projector calibration and then all of a sudden the screen turns white, what am I to do ?
Has anyone ever experienced this problem before ? It's making me a bit nervous to use the software. Comments would be appreciated.
--Sincerely,
MDS
I've never seen anything like that but here is a wild guess that is probably way off base...
Does the projector have any kind of 'burn-in' prevention software? There are a few different techniques like shifting the image slightly, screensavers, etc. (not sure if they apply to projectors). MAYBE because you left a static image up for awhile the projector changed the image to an all white background.
V
Vaughan Odendaa
As far as I know, the projector does not have burn-in prevention. What concerned me most was that the entire screen was white hot. Looking at the projector lens, it was just bright white.
Perhaps I left the test pattern on for a minute too long. I just hope that the problem goes away.
Thanks btw.
--Sincerely,
jeffsg4mac
jeffsg4mac
Republican Poster Boy
I have had that pattern and others on for long periods of time and I have never had an issue like that. Something may be wrong. Try shutting off your projector from the switch in the back. I had mine go all green once and that fixed it and it never returned. If that does not work, then you need to get it looked at.
Tom Andry
Tom Andry
Speaker of the House
I haven't used that disc so I'm only guessing here - perhaps it moved to the next test screen and that screen happened to be all white?
Edit: In retrospect, since this was my 666th post, I wouldn't try my suggestion. Who knows what kind of portal to demonic planes it might open up! :D
jeffsg4mac
jeffsg4mac
Tom, that was post 666, ooohhhh the devils post. heheheh muhahhaaa:eek: That would have been way cooler if it would have been on the 31'st.
Tom Andry
Tom Andry
Doh! I should have saved it. Especially since I've got something special coming out that day... ooooooohhh... foreshadowing....
