I have had a strange problem I think is probably related to a ground loop issue. For some time, my setup has worked perfectly except that from time to time I got a wailing, screaming sound (like a monkey whose tail is being twisted) that would start suddenly, and stop just as suddenly. Since it was so intermittent, it was hard to track down. After reading about ground loops, I listened more closely and realized that there was a very slight 60 Hz hum. I tried the usual thing of plugging everything into the same power strip, and that didn't solve it. (Slight caveat: My power strip wasn't big enough to handle all the plugs, so I plugged one power strip into the first power strip.) I did track the issue down so far as to decide it was the subwoofer connection that causes the hum.
As the next step, I bought a ground loop isolater and put it into the sub connection. I tried it two ways: grounded to the chassis of my amp, and not grounded. This has made the problem worse! Grounded, it brought back the screaming monkeys. Ungrounded, it transferred the hum to the sub (while the main speaker hum went down), but it also brought on some loud pop/crackle noises. Even worse, after I removed the device, the 60 Hz hum was worse than before!
My setup: (Note there is no cable box.)
Marantz AVR (this has a two-prong plug)
Sony TV
Sony DVD player
Roku box
2 main speakers
2 surround speakers
subwoofer
PAC SN1 ground loop isolator
What else is there to try here? Can I, for instance, run a separate ground wire from the chassis of the AVR to the chassis of the sub? Any suggestions will be welcomed with thanks!
