Wav to MP3 conversion
little wing
little wing
Greetings, and a happy Memorial Day to all. Don't forget to thank a vet!
I recently deleted the music I ripped off CDs in MP3 format. All my CDs are now saved on my PC in a Lossless (Wav) format. But I still need MP3 from time to time. Android phone, MP3 player etc. I found several free software sites that will convert Wav to MP3. My question is, does anyone have any experience with this type of software. Which one is better, easiest to use, and SAFE to download to your computer? Thanks
Haoleb
Haoleb
I am currently in the process of re-ripping all of my cds with EAC into FLAC files to replace the 320kbps MP3 files I already have. I used to use Cdex for that, and the program also has a feature for converting WAV to MP3. Cdex has always worked great for me and I know many others who have used it as well. It is also free.
sholling
sholling
I don't use a free program simply because I like dbPoweramp enough to pay the $38 for the full featured Reference version. It rips to the format of your choice (I use FLAC) while automatically tagging and filing everything the way you want. And then I use the included Converter to make a copy in MP3 format also tagged and filed the way I want it. They have a 21 day free trial.
dBpoweramp: CD Ripper & Audio Converter. Secure ripping to mp3, FLAC, m4a, Apple Lossless & WMA
psymonpsyko
dbPoweramp all the way. I've been using it since 2006 and it's worked wonders for me.
jonnythan
jonnythan
dbPoweramp is one of the few pieces of utility software really worth the money.
Anyway, WAV? Come on man. Use FLAC for long-term storage but encode to 190 or 256 Kbps MP3 for portable use.
little wing
little wing
Ok, thanks for the feedback. Seems like dbPoweramp is the way to go.
jonnythan - I am very new to this lossless format stuff. I use windows media player. It only uses Wav. What is the advantage of FLAC?
Thanks
jonnythan
jonnythan
Thanks
FLAC uses about half the space of WAV and allows for metadata like artist and title. There are some programs that can tag WAV but it's not a standard part of the format and doesn't work everywhere.
FLAC is the way to go for lossless music storage. Lots of players and programs work fine with FLAC, too.
MDS
But lots don't. ;)
I mainly use WMP, WinAmp, and Sound Forge. WMP doesn't support FLAC and Sound Forge only partially supports it (it couldn't read all the meta-data put in by dbPowerAmp).
WAV is fine if you've got the disc space.
little wing
little wing
Since I can't use windows media player with FLAC, which player would you recommend?
little wing
little wing
I have a PC with 920GB so hard drive space is not an issue. Thanks.
sholling
sholling
Lossless formats have tradeoffs. FLACs are much smaller and tags (embedded artist, album, and track data) are part of the official standard. WAV has more player support just because both Micro$oft and Apple refuse to support FLAC in their players because they want to force everyone into their own proprietary lossless formats. Foobar2000 is a very good (and simple to use) if slightly crude looking free FLAC compatible media player and there are perfectly functional free versions of MediaMonkey and WinAmp. Storage is cheap enough that it's just a matter of a choice between of if tags and file size or universal compatibility are more important to you. The nice thing is dbPoweramp will convert WAV to FLAC and FLAC to WAV with no loss in quality.
Getting back to MP3s a nice thing about dbPoweramps's converter is that it lets you choose a single file(s), or album(s), or the entire directory tree and then convert and file them as a batch. The only thing I'm not sure of is how (or if) it identifies and tags songs when creating MP3s from untagged WAVs. It needs to be able to identify songs if you want it to automatically tag MP3s and file them in a separate directory tree. During the CD ripping process it's able to identify the CD and compare it to an online music database and then automatically tag the songs with artist, album, and track data based on album information in that database.
its phillip
its phillip
more like v2 or v0 for portable use. cbr is bleh :D
its phillip
its phillip
I've used assorted portables over the last 8 years and every single one has supported vbr mp3 - while it is entirely possible that some will not, I don't think that issue would come up unless you're buying some $20 off brand player.
avnetguy
avnetguy
Winamp is usually very good at converting to MP3 and it's free! I believe both use the same LAME codec. Also, I'd stick with CBR for maximum support as usually you gain very little from VBR.
Steve
little wing
little wing
this is really good info! When someone says tag and file is that like just labeling the music?
When I rip a CD into windows media player sometimes it doesn't find the album info, so I have to search, and eventually it seems to find it. So when you convert to MP3, does the album and song info convert as well?
avnetguy
avnetguy
Depends on how the META data (artist, title, etc) is stored and the converting program used. Just run a quick test with one of your ripped CDs (WAV container) and see what gets converted to the ID3 tag on the MP3 file.
Steve
Tim De Baets
There's actually no need to switch to a different player. It is possible to use FLAC with WMP, by installing the Xiph.org DirectShow Filters for playback support, and the WMP Tag Plus plug-in for library and tagging support.
