Well, I knew something was wrong. The tag on the unit says 7.2 amps. I could not find the wattage in the owners manual either. It only shows wattage to the speakers. I did a little searching on the net an found a couple of reviews that state the power consumption at 550 watts. Thanks for pointing that out. I should have known better and taken a little more time. Using the 550W brings the waste heat down to 1500btu's/hr and the total cooling down to about 340 CFM. I still think this is a bit high.
I've looked at fans and fan cooling units, and peltier cooling devices. I favor the peltier because the $35.00 unit with heat sinks has a hot side of 190F cool side of 55F w/o fans. Add a fan to hot side and the cool side temp. drops, add a fan to the cool side and you have a ventless cooling system. Add an inexpensive thermostat and you have a hands off cooling system that's independent of the equipment it's cooling and keeps a more stable temperature in the enclosure.
I'm trying to use a few fans as possible to keep the noise down. In this case 2 120mm fans can do more cooling than 4 or more of the same size fans. There are fewer holes in the cabinet and less worry about dust being sucked in. Dust is a big issue in my house. It's almost 100 years old and falling apart 1 dust bunny at a time.
Bottom line is; I know this is probably way over kill... But I'm a glutton for punishment.
