Wanted: Set-up Mic for Denon AVR 3805
mxm
Need the set-up microphone for the Denon AVR 3805, for a reasonable price.
mxm
Does anyone know if the set-up mic that's included with the 2805 work with the 3805 as well? If so, I'd take that as well. Thanks. -- mxm
avliner
avliner
Yes, it does. If you have an SPL from Radio Shack, you might as well use it, instead of the mic. Also an average good mic will perform same as the Denon.
Cheers / Avliner.
