want a 2 channel Reciever w/ Subout?
Hipnotic4
Hipnotic4
Try to find a Nakamichi RE10
100W per channel (at 8 ohms, both channels driven, 20-20,000 Hz, with no more than 0.1% total harmonic distortion)
• Six audio inputs
• Three composite video inputs and two composite video outputs
• Adjustable subwoofer output
• Defeatable tone controls
• Loudness circuit
• 30 AM/FM station presets
• Heavy-duty 2-way binding post speaker terminals
AudioArcher
Nak
Nak has an AV7 as well. Haven't heard much about though
Hipnotic4
Hipnotic4
i cant find anywhere that is selling it..i think it goes for around 300
how much is the outlaw?
Z
zumbo
$599.00...........................................
Hipnotic4
Hipnotic4
you can either use that amp in fullrange or just for a sub..dont think you can do both..
I think Hipnotic is right - if you enable the x-over function, you cannot use the speaker outptus at the same time. In order to use it in a 2.1 config, you'd have to run the sub off the pre-out and the sub would have to be powered and have it's own crossover.
75w @ 4 Ohms means about 40-50 @ 8 Ohms, so it does't sound like this guy will get incredibly loud unless you use it bridged - loud enough for a medium sized room probably. My monoblocks are about the same size as that guy and run 180w @ 4 Ohms, so I'd expect the best use of one of those guys would be as a monoblock in bridged mode, though I don't see it listed as being 4 Ohm stable when bridged. It also doesn't offer any other functionality that a stereo receiver would, such as a remote, additional inputs for other sources, etc...
