Wallmount for Pioneer 1140 Plasma 50"
walter duque
walter duque
I am looking for an inexpensive (not cheap) wallmount for my display. Need a good, easy to install mount that'll fit the Pioneer. Any suggestions for a reasonable priced mount. I'd like to spend less than a $100.00. Thanks
Adam
Adam
I recall people having good things to say about the mounts sold at Monoprice.
walter duque
walter duque
Adam
Now that's what I am talking about. Great prices. Thanks for the link. For that price I can also mount my Samsung.
Adam
Adam
I'm glad that they have what you want! Perhaps some people here who own their mounts will chime in. I have no experience with them personally.
E
ephes98
Is the spacer necessary?
Newbie,
I'm in the process of wallmounting my Panasonic G15 plasma tv.
I'm just wondering if I need to include the spacer since the surface is irregularly flat.
thanks,
BMXTRIX
BMXTRIX
Wouldn't be bad to put a spacer or a couple of washers in there. Most flat panel mounts come with them, but you can pick up a few extra washers at any hardware store if you need to.
