Wall mounted speaker question.
movieprop
I'm about to wall mount my definitive technology XTR-50's for front right and left. Since they cannot be aimed/toed in, will this be a huge problem? They are about 6 feet apart and approximately 12 feet away from the sweet spot. Thank you for the advice in advance!
ack_bak
The speakers are designed to be wall mounted and not toed in. I don't think it will be a problem. Ideally I would think you would want the tweeter near ear level, but I would consult the manual regarding installation.
movieprop
Will do. I'll try to post some pics if the forum allows it.
