First post all. Nice to participate in this forum.
I've moved into a new home with a quite large living room. Measures about 20 feet wide, by 16 feet deep with the vaulted ceilings. It is open to the kitchen behind (not shown in the photos).
So previous Owners left some old junkers for speakers I'm looking to replace. You can see they've pre-wired for the front left corners, and also some in-walls for surrounds. I'd like to maintain keeping the speakers off the ground. I used to use some Monitor Audio towers + center for the front soundstage, but I'm going to place those in a separate room and keep them for music duties. So this room I'm speaking of here will be 95% TV and movies.
So what I'm shooting for is to roughly maintain this front speaker location, with NO center channel (phantom). I know, I know, not ideal.
Like I mentioned, the fronts are already prewired (it's an exterior wall so there isn't too much flexibility). With the new speakers up front I can lower them down a foot or two and probably not run into any aesthetic issues with existing pre-wire location.
Since it's basically all TV viewing here and I'm thinking a speaker that is impactful...something fun if you will, would fit.
I've done some research and I there are things like the CMT-340's...or HSU has a good bookshelf + matching in-wall combo. But I feel by going to a phantom center my set up is a bit out of
the ordinary and perhaps I should be looking at other specific characteristics of a speaker under this condition?
Budget is $1500 for the 2 fronts and 2 surrounds.
I've already got a HSU
VTF-3 MK5 HP covering the subwoofer duties...and depending on how things turn out may not be opposed to getting another down the road. Also have a Denon 1713 receiver.
PS, yes I'm aware this room sucks for a projector in its current state. That's a topic for another day.
