smulth
I'm new at this so if this question is repeated, I apologise. Does volume trim actually increase volume or is it only a percieved increase. Here's what I mean, if I enjoy listening to my receiver at -10 and then boost the volume trim to it's max and now listen at -23 is the actual volume still at -10. Just curious.
hopjohn
Trim controls are used to adjust and level the output of whatever channel/s your trimming. Since receivers generally have either individual trim controls for each channel or trim control for left/ight, surrounds, and rears you would use them to balance these levels. The volume control effects all channels levels proportionately.
Turning up the trim of say the mains, at a set volume level would increase the output you hear, but the actual volume level in terms of the postion of the control, remains the same.
Bottom line is, think of trim controls as gain controls used for minor adjustments & channel balancing, and the volume knob as your primary system level control.
dm_4u
dm_4u
Where does one make such an adjustment?
Is it possible on the RX-V2400?
