volume level
  • Thread starter Thread starter dobamar
dobamar
3
0
0
dear friends,
auto set up for avr-3805 showed different volume level of each speaker after running it.so the question is do i need to level the all speaker to equal level or let it play as auto set up has set for me.
thanks.
the auto set-up should have that fixed for you. you are ready to rock. :)
Yeah, most likely the difference in dB determined by the auto-setup is due to differences in your speaker placement and room effects. Trust its judgement unless your room and placement really doesn't lead you to believe the receiver's logic is correct. And you can double-check with a Radio Shack SPL meter.
