Well, it's been a long night. After leaving the forum last night, I went through all of your arguments - and decided to go "back to school" to learn as much as I could about CDs in a too-short amount of time. My schooling continues.
Great. At least we pushed you to expand your horizons
In reviewing my comments, it would seem that my arguments regarding laser reading should have been stated this way: "at the point of laser-read, we are dealing with optical, not electronic, properties. It would seem to me that any degradation of the optical path might lead to eventual audio problems - more likely on analog, not digital path, and most having to do with jitter, which I learn is more of a problem than believed by most people.
NO!!!. A degradation must be large enough for the optical path not to detect the data layer. Agan, there is no in between, there is no fractianl quality of reading the pits that will affect the analog output. That is why digital storage is so robust. You need gread problems, not small ones as playing a vinyl.
Jitter? You need to get factual references and information. It is not a problem, contrary to what some self appointed gurus may claim.
Articles by Jon Risch and others have been very informative!
NO!!! That is the last audiophile to listen to. His history is very long on the internet. His BS is vast. His voodoo, urban legends are unparalleled. He has nothign factual to offer except speculations what migh or may be. He has been so discredited that it is not worht the time reading his posts anymore.
Please expand you rhorizons beyong him, for your own sake.
I have e-mailed several electronics experts - but so far have only heard from one - and that on one of your assertions that laser light is transformed into GREEN light in the polycarbonate layer. Not true, says he, then goes on at length about velocity and frequency of light. He promises some written badckup from others - and when he sends them, I'll post links.
Who is he? Polycarbonate has an index of refraction of 1.55 that affects the red beam by that amount which shifts down to the green spectrum.
From this link, a few paras down
http://electronics.howstuffworks.com/framed.htm?parent=cd.htm&url=http://www.ee.washington.edu/conselec/CE/kuhn/cdaudio2/95x7.htm
"Each pit is approximately 0.5 microns wide and 0.83 microns to 3.56 microns long.
(Remember that the wavelength of green light is approximately 0.5 micron) Each track is separated from the next track by 1.6 microns. "
Why do you think they want you to remember the wavelength of green light is .5 micron?
Furhter down in that link:
"The polycarbonate itself is part of the optical system for reading the pits. The index of refraction of air is 1.0 while the index of refraction of the polycarbonate is 1.55. Laser light incident on the polycarbonate surface will be refracted at a greater angle into the surface. Thus, the original incident spot of around 800 microns (entering the polycarbonate) will be focused down to about 1.7 microns (at the metal surface). This is a major win, as it minimizes the effects of dust and scratches on the surface. "
Next para:
"The laser used for the CD player is typically an AlGaAs laser diode with a wavelength in air of 780 nm. (Near infrared -- your vision cuts out at about 720 nm). The wavelength inside the polycarbonate is a factor of n=1.55 smaller -- or about 500 nm"
Actually, there are too many relevant paragraphs below this one. Better read the linc carefully. The .5 micron is imprtant as you will see, for interference destruction
Also - here's a quote from a big-time skeptic on the eCoustics forum - who apparently was sent a free sample of Vivid by another forum member, and then used to test the product as well as Pledge.
snipped
His name, by the way, is Jan Vigne, and you can read more of the give-and-take on eCoustics>home theater forum>home audio>teaching an old dog new tricks (thread).
How do we know him other than a poster at that link? Is he a plant?
Did he do a DBT comparison? I seriously doubt it. Ask him!!!
Oh, this glorious waxing about the property of that snake is not evidence for anything.
