gene said:
Vinyl can sound superior to CD for ONE very good reason - recording quality.
In the days of Vinyl, recording engineers were careful not to exceed levels into clipping to avoid damage to the stylus. With today's LOUDER is better mentality of Radio, the industry is putting out LOUDER and LOUDER CD's that are pegged at 0dBFS and at best have about 6dB of dynamic range.
We have many articles on this topic in our Specs and Formats area.
Yes, and as I understand it the SACD format may benefit from the fact that there is a restriction to allow, or force, there to be some digital headroom in recordings. Possibly this is reflects the need for headroom due to the greater potential instability of single-bit converters.
skizzerflake said:
I've been hearing the "perfect" claims about cds since the beginning and I have always been aware that vinyl has surface noise, off-center holes, warps and all of those other errors. Also, I am assuming that vinyl is clean, not worn and played on a decent (though not extravagantly expensive) player with a fresh stylus and interconnects with clean contacts. The problem I have is that I can't prove anything or cite lots of technical terms but I almost always find myself saying "yikes that sounds good" when I hear good vinyl. Cds are not bad, but again, when I hear sacds I have the same impression. Since at worst there's no harm in increasing the sampling rate (we have the technology now, unlike 1980), and you can get cheap players that play everything...why not; why keep defending cds. Maybe I'm technically wrong, but my impressions and the impressions of other people I demonstrate to are so consistent that I can't ignore them either. It could be that the explanations don't address something about the sound but I can't ignore my ears.
It is not a claim of there being no distortion, but a mathematical proof that dither allows 16 bit recordings to have no distortion at all:
Vanderkooy, J., and Lipshitz, S.P., ‘Digital Dither: Signal Processing with Resolution Far Below the Least Significant Bit’, AES 7th International Conference – Audio in Digital Times, Toronto, 87–96 (1989)
I see that there are difficulties in examining the absolute performance of practical converters, both from a practical and theoretical standpoint. In saying this, however, there are objective tests with good resolution that can be run on converters, e.g. the null test:
C30 TOWARDS A DEFINITIVE ANALYSIS OF AUDIO SYSTEM ERRORS, Dunn, C., and Hawksford, M.O.J., 91st Convention of the Audio Engineering Society, New York, October 1991, preprint 3137 (P-1)
http://www.essex.ac.uk/ese/research/audio_lab/malcolmspubdocs/C30 Analysis of audio system errors.pdf
When I say good resolution, I mean that based on detecting distortion within what can be reasonably assumed to be the limits of human hearing.
When compared to conventional CD, I do recognise that SACD and DVD-Audio are objectively superior formats, but it is important to differentiate between variations in recording quality from differences in quality associated with the format. What I mean is that if you were to take a high-quality recording and convert it into the DVD-Audio, SACD, and audio CD formats, in a properly controlled test, it would be extremely difficult to discern any audible difference between the formats.
If you were to record a vinyl record with a high-quality digital converter, and convert it into SACD, DVD-Audio, and audio CD formats, I again suspect that there would be very little audible difference between any of the different formats when compared to the original vinyl recording. Stanley Lipshitz once did this sort of test with a digital adapter:
http://www.bostonaudiosociety.org/bas_speaker/abx_testing2.htm
The extended frequency response available with SACD and DVD-Audio has been shown not result in any audible difference from recordings limited to a response of 21 kHz:
Nishiguchi, T. et al. (2004). "Perceptual Discrimination between Musical Sounds with and without Very High Frequency Components", NHK Laboratories Note No. 486, NHK (Japan Broadcasting Corporation).
http://www.nhk.or.jp/strl/publica/labnote/lab486.html
