Hi!
I'm restoring a pair of Acoustic Research AR-90 speakers.
I just finished the crossovers.
There is no PCB. They are made using direct point to point soldering of components.
I have new caps, wiring and speaker binding posts.
At one point I got stuck when I had to solder two bundles of thick solid core wires to the speaker binding posts.
My soldering iron was not powerful enough. It couldn't provide enough heat, so I was not able to do everything in one go.
I was kind of building up things by adding solder partially to different spots. Finally, I ended up "sculpting" solder with my
iron.
These are the binding posts in question:
New internal wiring is solid core 14 and 16 AWG Neotech UPOCC (monocrystal copper) wire.
Here is the result.
It looks kind of ugly, but I can assure you that everything is rock solid and that there are no cold solder joints.
Before doing any soldering, I tried to make a good mechanical connection between the wires and the speaker binding post
lug on their own, without any solder.
On this sketch you can see that lug has a hole, so I had one wire going through it to the other side, where it made a loop
around twisted bundle of other wires and then it went back.
After looping and tying the wires and the lug together, I squeezed everything together with pliers.
Only after that I started soldering.
My question is:
Are there any sonic penalties that can be heard with such a bulky solder joint in a speaker crossover?
I hope that I'm fine and that it won't sound worse compared to some nicer looking solder joints, but who knows?! I'm not an
expert on these things.
On the internet, I can read a lot of audiophool voodoo stuff.
Some of it regarding crystal or submolecular metal structures and things like that.
In that light, those solder joints look really bad!
So, am I going to be able to hear it or not?
What do you think?
Thanks in advance,
Aleksandar
