Hi There: Have a new AV receiver and are trying to utilize S Video for all components. Works great with DVR and DVD but not with older analog components such as VCR and camcorder. TV is about 7 years old, has S video and two separate AV inputs and one AV output. If I hook up the DVR and DVD to the TV, switched through the receiver on SVideo, all works well. Adding a VCR with no SVideo, just component outputs and inputs results in no video output but audio is fine. One solution is to scrap all the sVideo cables from the components and wire a video composite* cable between the components, receiver and TV. This works but I really want to get the higher video quality that Svideo offers. I could wire the VCR directly to the TV inputs but then I cannot take advantage of the receiver's sound. Is this a common problem with older analog devices? Same problem happens when I connect my camcorder to the front panel inputs, audio is fine but no video. Any ideas? Thanks a bunch!
*[edited from "component" to "composite" - Admin]
