Thanks for the response.
Yes the subs are different brands (one is Sunfire, the other a cheap JVC).
The move was about 5 - 7 miles as the crow flies.
Any ideas about what can cause this kind of issue? How to isolate it?
5 to 7 miles is not far. So there could be piece of equipment in that region, probably industrial related, that is sending interference back down the AC wires, and getting distributed by the power company.
The other issue is RF from some piece of electronics, like a fridge, deep freeze, or convection oven that moved with you.
What devices that contain motors moved with you? Switch them off one by one by one and see if you can find the culprit.
If it is mains introduced you likely won't nail that without instruments like scopes. You can contact the power company, but they are usually very unhelpful with these kinds of issues.
You could try putting RF chokes in the mains lead to the subs, and see if that helps. If not the only thing you can do is buy a high grade sub that does not have a switching power supply. Switching power supplies are notorious for transmitting mains interference. Those power supplies are widely used to power the class D amps, that so often power subs.
We seem to get more darn sub issues than any others. I'm rapidly coming to the conclusion that most subs are poorly designed and built and are just trouble.
The case for building your own with a decent amp is getting stronger and stronger. Many on these forums do and I think that was time and money well spent.
I don't own a commercial sub and never will. I'm glad I don't have to tangle with those troublesome units.
