Velodyne vs.SVS vs.HSU vs. M&K
Mailhandler
Happy New Year!
Listening area is about 4000cu.ft.(open space). Using B&W 705's for Mains,Center and Surrounds. Pushing them with Onkyo SX-TR 700. Probably will need 2 subs. Which of the following will kick butt on music and home theater.
Velodyne-SPL-1500R
SVS PB12-Ultra/PB12Plus2
HSU-VTX-3 HO
M&K?
Sheep
Sheep
I'm going to go out on a limb here and say the PB-12plus/2 would have the highest output.
The Velo is big, but it's not going to be that loud.
The Hsu would do pretty well, but the /2 would probably have more output. These are 2 subs I'd like to see commented on, as to which is better give their price and size.
The M&K units (push pulls) are supposed to be pretty good, esp. the THX ones with a selector switch that will give the sub a flat anechoic response to 20Hz. With that engaged in a room it could do very well.
SheepStar
Peter Marcks
Sheep, don't forget that for a bit more than the cost of a VTF-3 HO, one can get dual VTF-3 Mk3, which would offer some very serious output capability!
As an alternative, adding an MBM-12 to a VTF-3 HO will provide about 10db (!) higher headroom in the mid/upper bass.
Also, the VTF-3 Mk3/HO with turbocharger will move as much air as DUAL -3 Mk3/HO in extended bass mode w/ port plug for a given level of port noise.
Seth=L
Seth=L
I loved my M&K untill the power supply shorted out.:( It was a sad day for mankind. I am getting it repaired soon though.:D
Buckeyefan 1
Buckeyefan 1
I've got just under 4000 sq ft, and my Plus/2 rattles the windows in other rooms. I can't imagine needing more than a Plus/2. You may be fine with one VTF-3 Mk3/HO with turbocharger, and it's less expensive than the Plus/2. I'm just not sure about the looks. The Plus/2 in oak makes a great end table. :rolleyes:
Sheep
Sheep
I was hoping you would comment. Seems the plus has more then enough. Might as well save some dought and grab the VTF-3HO.
SheepStar
Warpdrv
Warpdrv
http://forums.audioholics.com/forums/showthread.php?t=28043&page=2
One look at my new sub, and I couldn't imagine owning something with a turbo..
8200 cu. ft. to fill here... and it shakes My son's room clear across the house..
What more could you want...
Lovin my SVS PB12-Plus/2 RoseNut
Warpdrv
Warpdrv
Warpdrv
Ryan8886 said:
Hey Warp!
That does look great! Bet it rocks the walls too! Glad you're happy with the new addition!!
Well in addition, I just got a Rotel 1095 200 x 5, and a temp Pioneer receiver that is just shreading my house to pieces.. Im totally in love with my setup, and I haven't even gotten my new speakers...
Thanks Im loving it so much..
