VCR audio recording problems
L
laxjester
I just setup my system with a new HDTV monitor and a motorola HDTV tuner from Comcast. Everything is working great except the fact that I can record a program that runs through the tuner but it will not record the audio. I have moved wires in and out all kinds of ways and nothing seems to be fixing this problem. Wehn I have my rec'r switched to the VCR I can see the video on the TV but the sound will not work. Here is my hookup:
Cable in to splitter. Coaxial out to HDTV and to Tuner. Coaxial from tuner to VCR. Composite A/V from VCR out to A/V Rec'r and composite video out to HDTV. Tuner component out to HDTV. Optical to A/V Rec'r. DVD component to HDTV with optical to A/V Rec'r.
I feel I have tried all kinds of combinations to fix the VCR audio problem with no results. Any help would be greatly appreciated. I had basically this setup with my digital cable setup except the addition of the digital audio and it worked fine for everything. I'm not sure if the digital audio connections are messing things up or not.
