Variable audio from Yamaha receiver
SilverLynn
SilverLynn
I have a Yamaha HTR-5860. While I am watching a program (from cable or a DVD) the sound level randomly decreases for about a second or two and then returns the level it was supposed to be at. This happens sporadically, about once every few minutes when it is happening (which is not all of the time). What could be causing this? Thanks!
jamie2112
It sounds like you have some kind of compression going on from your AVR. Are you running your Yammy stereo or are you you using an onboard decoder?
SilverLynn
SilverLynn
It doesn't happen when it is set 7-channel stereo, it happens on the preset "Movie Theater" programs and on Surround Enhanced.
