Utilizing existing Speakers
K
kpierce
Hello:
I have a room that was pre-wired for either stereo speakers or 4 surround speakers.
I opted to put in the two stereo speakers in the high ceiling and leave the other two connections 'capped'.
I am now thinking about putting in a very inexpensive surround sound system.
I am thinking I could just buy an inexpensive A/V receiver, two more 'stereo' speakers and a middle speaker.
Or would it be better to buy a complete 'setup' and install.
My question is will these current stereo speakers be sufficient for back speakers? They 8.5" 80Watt speakers. That is all the specs I have on them.
For the front speakers would the same be sufficient.
I guess my real question is, are the back and front speaks different than just regular stereo speaks?
thanks
mazersteven
mazersteven
I think we would really need to know what speakers you have now.
Also what are you trying to accomplish with this system. Full home theater? Background music? Multi-Channel Audio?
And when you state "stereo speakers" are you talking about in-ceilings with duel tweeters?
Hello:
thanks
No where near enough information for a considered reply. But if it's cheap you want, that what you will get, anyway you slice the cake.
