Using component cable for SPDIF audio.
Sleestack
How do you guys know the Ohms of variuous types of cables? I'm wondering if I can use one strand of a component cable for SPDIF audio.I had ordered a 25' component and a 25' coax... unfortunately, they delivered 2 25' components. Instead of dealing with the hassle of a return, i'm thinking about using the component cable as 3 separate audio coax SPDIF cables. Will that work?
Thanks in advance.
jaxvon
jaxvon
If memory serves correctly, SPDIF is a 75 Ohm cable, so yes, Component video cable (assuming it's made correctly for 75 Ohm impedance) will work fine.
Edit, just checked, and yes it's a 75 Ohm cable.
Sleestack
Thanks.. you have answered alot of questions for me on this forum. I really appreciate it.
jaxvon
jaxvon
Meh, it's no problem. I just answer what I can. It just so happens that I know the answers to your questions!
