Using Audio Precision to measured THD and S/N ratio
cayman
Dear all,
I'm new to audio testing field. My company recently purchase an Audio Precision ATS-2 for audio product testing. At the moment I'm trying to learn to measure the S/N and THD, but the manual has no information on S/N ratio and very little for THD.
Is there anyone known any website which shown how to use the ATS-2 software to do measurement? OR is there anyone known how to find the THD and S/N using ATS-2?
Please help.. thanks in advance.
Cayman :confused:
gene
gene
Audioholics Master Chief
Administrator
Cayman;
The AP has a THD drop down in the Analog Analyzer. For SNR there are quickset files and you can also do them manually. Check out their website at:
http://www.audioprecision.com
They also have a training DVD which I will be using shortly to expand my knowledge base. AP by far makes the most advanced audio analyzers on the market. Take the time to learn it and you will unleash its power!
