Using another Subwoofer with Bose am10
E
elit
Does anybody know if its possible / or what is the best way of using the small cube speakers of bose ,but with a non-bose subwoofer ?
Karp
Karp
Why not just sell the Bose to some unsuspecting person and buy some "real" shelf speakers? Anything over $50 a pair would give you a huge improvement in audio quality. This would be your best option.
If you are using a receiver with LFE/Sub out, just run a RCA coax cable from the receiver to the sub's low level input and set the crossover on the receiver as high as possible. I would recommend 150Hz if it is an option. Unfortunately, you will be able to localize the sub, but at least the little cubes won't be trying to produce sounds too far below their capabilities.
You can also run the speaker wires to the sub's high-level input and from the sub to the cubes if you do not have LFE/Sub out. Adjust the sub's internal crossover till it sounds best to you.
Let's face it. A 2" paper cone that costs Bose $1.50 cannot possibly reproduce effective midrange (let alone bass) unless you are in a VERY small room and listening at VERY low sound levels.
mikepinkerton
This is exactly what I did 4-5 years ago and never looked back. For the same price as the AM-10 I got a full 5.1 setup of Paradigm speakers and sub. The difference in the first minute of listening was amazing.
To answer your question, if your rcvr has a subwoofer pre-out, you can just buy another sub, but you'll still have the passive Bose sub playing as well. There's no way I know of to bypass it as it routes the sound itself to the mini speakers.
-Mike
