Worth $500 NO! but a difference, YES. The components in the NAD or another high end company, are usually of higher quality and different topologies than that of a consumer receiver, ie. slit-foil capacitors, etc. But, the yamaha's are known for using higher end nichicon caps, and high quality discrete power transistors, so they kinda mimick the higher end gear in a way, but if you have a ford, it's still not a Jaguar... The RX-V series of receivers are known as well to be the better of the 2ch music performers in the receiver market, the HTR series is for more movies and best buy stores. I have had about 5 RX-V series yamaha's and loved the stereo reproductionof all of them, especially the older units, but the separate pre-amp / power amp is the way to go for music only. Receivers are focused on home theater so much, they do cut some corners in the power amp section to not be as robust and lack the 'headroom' of a good 2ch separates system. The 1800 is a way good choice for the money, and may be the sound you're looking for, but if you are 80% music and 20% movies.... go have a listen to some gear in your price range... it may be the better choice if you have a picky set of ears.
