"Your information is contradictory. First you say you’ve gotten sound to the speakers (minus the sub), then you say you can’t get audio from the TV. Where did the sound in the first paragraph come from? "
From FM radio. Without an antenna, all I get on FM is hiss - but it's enough to know I get signal to the speakers. Just not on all 5 at one time. Best I can get is 2 at once on 2 channel setting.
"But if you smell something funny when playing at high levels, or if one or more speakers simply quite working, you’ll know the resistor burned out and opened up the connection."
I usually don't run it that high - but I'm beginning to understand what I'm faced with. I actually don't know the power rating of my Phillips speakers so I may have to nurse this along until I can add to the system.
"The mystery is, what is the computer putting out via its HDMI output?"
I have "Realtec Audio Manager" in Windows 7 running stereo L+R with a powered Subwoofer. My computer's back panel 3mm Audio goes to the back of the subwoofer which drives the speakers.
My HDMI cable is plugged from my AMD Radeo 7800 Series Graphics card to one of two HDMI ports on the back of the LG TV.
If my computer puts out Video to the TV, can it also put out Audio to the receiver? Is it throughput through the TV or directly to the receiver?
I think HDMI from the computer to the TV sends both Video and Audio. The TV's speakers work - I just don't use them. If I use an HDMI>TOS converter, (which I just ordered) will that plug from my Graphics card's second HDMI port, directly into the TOS port on the back of the receiver? Is that 6.1 capable or is 6.1 a function of the sound card on my computer?
I'd like to plug into the receiver in some way that will drive at least 5 speakers at once. Maybe I can find a way to connect my other powered Sub Woofer to the receiver.
Thanks and best wishes,
Mike Kowalski
Twentynine Palms, CA
