b52lord
Hey, just wanted to see what your thoughts are on whether it would be worth investing in a USB (external) sound card? I have fairly powerful laptop with an integrated sound card that I use to play games on. If you think I'd be worthwhile, could you recommend any for me? Also I'd like to keep it under $100.
Thanks
BoredSysAdmin
BoredSysAdmin
Thanks
What speakers you have now which connected to your laptop?
This is help determine if adding usb audio card will be worthwhile...
Don't get carried away spending $100 on this card, if your speakers cost less than $100 ...
but If I'd rec any usb dongle - this will be the one:
http://www.bhphotovideo.com/c/product/422094-REG/Behringer_UCA202_UCA202_USB_Audio_Interface.html
jinjuku
jinjuku
Moderator
What is it:
1) You hope to achieve?
2) Think that you may be missing?
bikemig
I know that there are people who swear by the inexpensive behringer usb dac that BSA recommended. It's cheap and it seems like it works. That said, if you have a revealing sound system, you could try the HRT musicstreamer II. It made a very nice positive difference in the SQ of my set-up. http://www.amazon.com/HRT-Music-Streamer-II-Resolution/dp/B0038O4UFQ
c0nnect3d
I just bought the HRT Music streamer II, and I love it, it work perfectly out of the box, no installation required.
