mudrummer99
Hey everyone,
A friend of mine gave me an MX-350 with the rf repeater set (yeah, he didn't like it and I thought, why not, I can make it work) Well, I'm having trouble making it work. I'll be honest, I haven't even tried looking for the owner's manual online at all, but I was wondering, how does the programming on the URC remotes work? I have never used anything but Harmony and was curious about it. Any feedback would be greatly appreciated as always. Thanks in advance.
Mike
E
EJ1
I remember playing with an MX-900 and the software it came with it and I couldn't figure it out, haha. I couldn't make a macro to save my life. I guess I was spoiled with my Harmony. I loved the feel of the URC remote and wished someone could have taught me how to program one. I'd still have it if that were the case. Also, I'm not sure if the MX-350 is programmed the same way or not. Did you get the MRF-350 as well?
mudrummer99
If that is the RF to IR receiver/repeater, then yes I did. I don't have any software that would have come with it at all if it did. Would it be possible to find this online somewhere or do I need to gank a disc from somewhere?
Mike
Highbar
A quick scan of the first 5 pages of the manual online shows that you have to enter the codes manually of "teach" the remote. You are going to have to download the manual and look through it to find the codes you need. I think it list 20 or so pages of products and codes. No software for that model.
Good Luck
mudrummer99
Thanks everyone for assisting with my laziness, now off to program macros for the next 4 hours :rolleyes:
Mike
MDS
The MX-350 is programmed manually, directly on the remote itself. Like most universal remotes, it includes a database of 'setup codes' but I would advise against using them. The main reason being that you have no control over what commands are placed in what order on the LCD buttons on the side of the screen.
If you don't have an original remote for a piece of equipment, you'd have to use the built-in setup codes but if you do have the original remote it is far better to plan your layout, label all the LCD buttons, and then teach the MX all of the commands from the original remotes.
Programming goes really quickly once you become familiar with the process and one advantage to manual programming IMO is that you can make changes on the fly while sitting in front of your equipment. Macros in particular are things you often don't get perfect on the first try and being able to do it while sitting in front of the equipment is a lot easier than connecting it to a computer, firing up the software, making changes, disconnecting, testing, and repeating that process again and again until you get it right.
jostenmeat
+1 . . . .
