Upgrading Me System,Need Help
Hummada1
Allllllllll Right,
What I have here is...
Def Tech
BP7006-fronts
2300-center
BP-2X-surrounds
Denon AVR-1905 reciever
Denon 1920 Universal
What I want my upgrade to be...
Def Tech
BP7002 as fronts
3000 as center
I will be using the BP7006ers as surrounds and the 2300 center as back surround.
My questions are...
Will the 3000 blend in,since I'm suppose to be using the 2500 center with the 7002's(it is recomendedto use the 2500 center,but the 2500 is not much of an upgrade)?
Will my 1905 reciever be able to handle all of these large speakers?:confused:
What recommendations would you have to upgrading me system?
Hummada1 said:
Allllllllll Right,
Def Tech
BP7006-fronts
2300-center
BP-2X-surrounds
Def Tech
BP7002 as fronts
3000 as center
My questions are...
Speaker physical size is not the issue for an amp. A speakers impedance throughout its whole frequency range and its sensitivity. Then the amps power capability for that speaker load. And finally, how loud do you listen.
Hummada1
I usually listen to music from negative 20db-negative 10db.
Movies(I usually only buy DTS),about -17db
I think my reciever goes to 18db. I turned it to 10 db one day and almost blew my friggin ears!
Then, you should be fine with what you are contemplating. Enjoy, not agonize over them:)
Hummada1
I'm not agonizing. I already love my set-up now. I'm just making shure things will go smooth when I make my purchase.
Because I am just learning about audio, I'm trying to jump ahead of any BS. I've read many articles and forums and most of it is BS,so it is hard learn about audio on the net.
Thanks for your input mtrycrafts:)
