First, Listen to what the system sounds like.
If you feel the center channel is weak, upgrade it to the energy LCR. You want the same timber across the front 3, so the infinity will not be ideal. The specs only determine the limits of the speakers sound (from Nhz - NKhz). It doesn't mean they sound that same in the middle.
SheepStar
