New member to the Audioholics.  Home Theater knowledge extremely limited.
I am neither an Audio or Videophile.  I would just like to put together a decent system to enjoy a better or improved quality of television viewing.
I rarely rent or buy video media.
I recently purchased the Sony KV34HS420 HD ready wide screen and the Sony RDR-GX300.  An earlier attempt at HT was the purchase of a Sony STR D1011 A/V receiver, Atlantic Technology System 150 HT speaker system...# 151 L and R, 153 Cntr., 154 Surrounds and the power-directed Sub.  The 5 spkr's. are rated  @ 110 W, Sensitivity @ 89dB...8 ohms,  I know its dated but I was hoping to still be able to use it with todays advanced recvr's. (the spkr. sys. that is).  I imagine the Sony A/V would go south.
I recently had DishNetwork Satellite installed with the HD 811 receiver for the main viewing room which is 14'w x 20'L an opening to the kitchen behind the seating for viewing the TV.  The cntr. spk'r. is above the
TV but with a swivel base to cast it either up or down as fitting.  The mains (bookshelf) are spaced approx. 40" either side of the TV.  The sub is located on the floor, same wall as the TV but to the left.
I forgot to mention (if it is relevant) the Dish Pkg. also included the HD Pkg.
I hope that I have'nt rambled on, in leading to my main concern which is deciding on a new A/V recv'r.  I believe that the unit I described above would not handle todays advances in HT.
I would greatly appreciate any input regarding the selection of a new A/V in the price range of $300.-400., and any other suggestions regarding the usability of the speaker system I have.
I would also appreciate being guided as to cables required for maximizing the hook-ups for the described units,( i.e. optical digital, digital coax, the 811 has optical out, the DVD has both) I am aware of  one I need, that being the DVI from the  811 HD satellite recv'r. to the HDMI at the TV.
As anyone viewing this might discern, I need some guidance.
I thank you.
