I
icngacsn
Can anyone recommend an "upconverting" or is the term "up-scaling?" receiver, or better still provide a list? So far I have found the HK AVR 7300, the Denon 3805 and the Yamaha RX-Z9 AV only do conversion (though one review said the Yamaha did upscaling of DVDs to 720/1080 only if the disc was not copy protected - not much use to me).
My issue is that I have a Sharp Aquos LCD TV that constantly screws up when I change channels from 480 to HD on my cable/SAT box (it displays static at 480 instead of HD at 1080) and I need to re-set the TV (power cycle or change inputs) to make it display HD. I know, you are saying "get it fixed" but I've had little luck with Sharp on that subject... so I thought I'd give up and solve the problem a different way. I want to use 1080/720 for all inputs (DVD, SAT & Cable), and would like any OSD to also work on all inputs...
Any suggestions?
icngacsn
Any suggestions?
icngacsn
