I recently purchased the Westinghouse LVM-42W2 monitor, and was possibly looking to get an up-convert DVD player to go along with it. The one I have my eyes on is the Panasonic DVDS52S, which I can get for less than 100 bucks. What pointed me to that one was that it was one of very few that have a DTS converter built in. While my receiver has a DTS decoder, too, I found out that unless the DVD player has one built in, I get no sound from my TV, just the surround speakers. This happens whether the DVD player is connected to the receiver via coaxial or optical. Whether this is legit is another story; I just know that's what I experienced.
Moving along (albeit very slowly), I guess part of my question has to do with whether I'll notice a difference with the up-convert player. I've been told that if the TV has a good scaler/de-interlacer, up-convert doesn't really matter. Is this true? The Westinghouse apparently supports 1080p through component cables, so would the built-in scaler automatically up convert standard DVD? If not, and I have to get the Panasonic up-convert, by what means should I connect it to get the benefit of up-convert and full surround sound (DD/DTS) where appropriate? Would the component connection work, given my TV, or would the HDMI connection be sufficient?
The reason for my question is that a while back I tried one of the Toshiba up-converts, and when I made use of the HDMI connection, it included the audio, but not in full, 5.1+ surround. But, it didn't have the decoders built in. I just want to make sure that the same thing doesn't happen here. Furthermore, I want to get the best quality across the board as possible. Any help would be greatly appreciated.
Thanks!
