May the circle be broken...Part 2
7. Bear in mind though that the original question was "can you use identical speakers?"
Incorrect, see answer to #1 above.
8. Floyd Toole's most recent research indicates multiple subs pulled well out of the corners is far superior to corner loading.
Incorrect. Multiple subs pulled well out of the corners lose a potential of 6dB of "free" gain which you get when you move into a corner. What those subs pulled out from the corners DO gain is the Potential to exhibit less peaky response in any one given frequency or frequencies eqif no means of equalization are available.
The corner mounted subs on the other hand have much More Potential to excite a single peaky response which is dealt with using single band parametric EQs like Infinity's RABOS. Dr Toole, in his seminar showed several configurations of multiple woofers; all four corners, two front, two rear, along their respeactive walls, even four subs out into the room and firing from the ceiling.
The point is, what Floyd's research department has found is that once you've got a system which can equalize 2,3,4, 5 subs all at once in a room, using a single band of equalization on each, you've pretty much got the problem licked. As Long As They're Subs!
9. I'll agree that running the mains all full range may not be optimal, but oddly enough that's been Sony's recommendation with regards to SACD, and they're not the only manufacturer to do so.
Well sure. Sony has pushed SACD for years. To them it is a separate issue from watching movies. Remember, back when SACD and DVD-Audio were still being discussed as to who would be the standard, the buff mags at the time were saying that to do it right you needed a dedicated audio system in one room and a dedicated video system in the other. Hard to believe, looking back. Now Sony appears to be backing off of SACD altogether and they never have been a presense in loudspeakers, so what do they care?
10. When dealing with full-range speakers all around, has anyone actually tested how much bass cancellation occurs?
This is an impossible question to answer. Every room/speaker combination will be different. Note the Recording Engineers recommend that all five full range speakers be the same distance from the mixing position but within a range of only 6.5 to 7.5 feet! Think these guys haven't figured out what a problem this arrangement already is?
10. I’m not sure, but wouldn’t cancellations/reinforcements be most noticeable if mono bass were coming from multiple places at the same time? In non-mono recordings, wouldn’t there be different sounds coming from each speaker?
Cancellations/reinforcements would be noticeable with mono bass If the sub is not properly positioned so that a bass peak exists. But, if the sub is properly positioned so that the sub has a linear response across its frequency range than no frequency will stand out from another. This can also be accomplished by putting a sub where you want it and using a 1/12 or 1/20 octave parametric EQ to attenuate the single frequency peak that most commonly exists.
In the case of "full-range speakers" playing "non-mono", non-encoded recordings, yes, you would get different bass notes coming out of each speaker. The question then becomes how low in frequency is the note, where is your listening position , and does that frequency create a room mode right where you are?
11. I was addressing the issue of placing full range speakers operating at full range bandwidth at standard main + surround positions simultaneously
See #10 above re: the Recording Academy recommedations. And read all of the document. Because some points seem to contradict others.
11. While it is true that a large number of subwoofers can [1]potentially even out response, the positioning resulting in this effect is [1][2]unlikely to occur at the standard combination of coincidences of the main left, right and left, right rear surround positions. I am not aware of a Toole study on this particular issue.
Absolutely correct. This is the point Floyd makes in his CEDIA seminar. We never, ever deal with a perfectly rectanglar box for a room. Once a door or window is put in the room the computer simulation (for a perfect room) is worthless. This again is the reason that Floyd and his guys have developed the multiple subwoofer computer equalization program. One band of parametric equalization per sub is all they're using at present. With that he's shown a slide which gets his four subs in his personal living room/home theater within + or - 3dB anywhere in the room. He says the effect is eerie. And indicates that before this system gets into production they may get a tighter performance window out of it.
