SMM said:
Fortunately I have a conduit from the projector back to the equipment closet so I should be able to snake another wire in there. What is the practical distance that the wire can be run? I have to go approx. 40 feet.
Some of my components clearly mark the IR receiver on the front display, others don't. How do I determine where to mount the IR Flasher on those that don't identify the IR receiver?
I don't know what the practical limitation is with the electrical signal for IR. Since the flashers literally are little IR lightbulbs, it is an electrical current, so it depends on the wire in use. Over CAT-5 I have run it well over 100 feet without issues.
For finding an IR location on a piece of gear, use a small flashlight, like a pen light or something similar and put it on the black face of the gear. It can be hard to see, but typically in the 'clean' face behind the black, you will light up an IR receiver which is typically a small round object that looks similar to an LED light. Only, it is black most often. Sometimes you make mistakes and it IS a LED - so some testing and playing with it may be in order. When testing for IR receiver location, I often will program a remote with just the power toggle for that device and move the IR emitter around while pressing the button until I find the exact location to put the IR bug onto.
More often, I don't like IR emitters on the front of my gear, so I open up the piece of gear, find the IR emitter inside of it, and tape/glue the emitter and wire inside the device (DVD, VCR, cable box, etc.) and then put the case back on. With just the wire coming out the back, it keeps it clean and you don't mistakenly knock an emitter off - or have a friend 'pull' it off when they shouldn't.
