Hi all, my first post, my name is Roger.
For some background info. I live in a MH with a breakfast bar separating my kitchen and living, but otherwise a wide open 16' by 30-32'. My main listening position is about 5' from the left wall and about 10' from the right wall.
My equipment so far is a pair of Polk monitor 50's for my mains, and the Polk monitor cs1 for the center. I am running a Klipsch Synergy 12 sub. I am running a Denon AV-1708 receiver that produces 75wpc. These are against my front wall(with the opposite wall being 30ish feet away) and my listening position is aprox 10' from the speakers. It sounds phenomenal as it is, however I want to add 2 Klipsch s-10 bipole speakers for the rears, mounted to the ceiling at 8-9'.
My first question is; will the sound integrate properly, given that the speakers will not be equidistant from the side walls as they will be centered on me? They will be about 2-3' behind the listening position. This will put them about 16 off the back wall.
Next, are there any suggestions on what speakers I should use for the side speakers? The will also be hung from the ceiling at the same height as the rears. Should I go with direct firing or do you thing I could use S-10's for these positions as well(being that these will be 18-19' off the back wall)?
Thanks for the help.
