How can Amplifier manufacturers say there amps can push x amount of amps if the wall sockert can not handle more then 15amps?
Such as the Music Fidelity A5cr.
Power 255 Watts per channel into 8 Ohms (24dBW),
416 Watts per channel into 4 Ohms
Voltage, RMS 45.2 Volts 20Hz to 20kHz
Voltage, Peak-to-peak 118.8 Volts
Current peak-to-peak
200 Amps
Damping factor 170
Output devices per channel 8
So does it come down to the power supplies and caps storing the amps as needed?
I am just looking to understand, not to cause me to be abused
