I was tooling around the B&W site when I came across their new top end center channel. Check this baby out. Three, yes, THREE eight inch woofers, one Six inch FST midrange and one, one inch diamond tweeter. AND the Midrange and tweeter are in their own respective Marlan enclosures like the rest of the 800 series. Oh yeah, and it weighs 205 LBS!!!!!!
From B&W:
The HTM1D is the largest of four centre speakers in the 800 Series. It could be considered an 802D with a different aspect. The full configuration of FST™ midrange in a Marlan® sphere/tube 'head' with diamond dome tweeter on top is used, so that the system perfectly voice matches either the 800D, 801D or 802D in a substantial and powerful multi-channel installation.
To supply the prodigious bass power necessary to keep up with these powerful main speakers, the HTM1D uses three 200mm (8 in) diameter Rohacell® cone drivers with twin rear-firing Flowports™. All drivers are, of course, magnetically shielded to avoid picture distortion with CRT-based screens.
The HTM1D is specifically intended to be mounted on the floor, its low profile allowing a large projection screen to come within 600mm (2 ft) of the floor. Supplied with the system are four heavy-duty height-adjustable feet. This design allows up to 40mm (1.6 in) of vertical adjustment so that the speaker may be tilted back to face more towards the listeners. They have a case hardened spike at one end for carpeted floors, and a non marking rubber pad on the other for more vulnerable surfaces.
http://www.bwspeakers.com/index.cfm/fuseaction/products.models/label/Model HTM1D
Specs:
Technical Specifications : HTM1D
Description 3-way magnetically shielded vented-box system
Dimensions Height: 585mm (23 in) (not including feet)
Width: 974mm (38.3 in)
Depth: 580mm (22.8 in)
Net Weight 93kg (205 lb)
Freq. Response 38Hz - 28kHz ±3dB on reference axis
Freq. Range -6dB at 32Hz and 33kHz
Sensitivity 90dB spl (2.83V, 1m)
Normal Impedance 8 ohms (minimum 3.7 ohms)
Power Handling 50W - 1000W into 8 ohms on unclipped programme
Drive Units Unit 1: 1x 25mm (1 in) diamond dome high-frequency
Unit 2: 1x 150mm (6 in) woven Kevlar® cone FST midrange
Unit 3: 3x 200mm (8 in) Rohacell® cone bass
Finish Cabinet: Real wood veneers of Cherrywood, Rosenut or Black Ash
Grille: Black cloth
Dispersion Description: Within 2dB of reference response
Horizontal: over 60º arc
Vertical: over 10º arc
Harmonic Distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 55Hz - 100kHz
<0.5% 100Hz - 100kHz
Crossover Frequency 350Hz, 4kHz
Max. Recommended Cable Impedance 0.1 ohms
