Two mics, two amps, 3.5mm to splitter, to PC - Why only getting audio from left side
RedCharles
I bought aWhat am I mic, and an amp, and I hooked it up and realized that I was only getting audio from one side. And this made sense, so I thought, I'll record in stereo with two mics, so I bought an identical set up and connected each side together with a 3.5mm splitter. However, I'm still only getting audio on one side. What am I doing wrong?
This is a video link of what I'm having trouble with.
https://1drv.ms/u/s!AvsO0rkUe83shrwYx33ggRP7f3XcrQ
WaynePflughaupt
WaynePflughaupt
The output of the Rolls pre amp is 1/4” unbalanced, which uses a so-called “mono” plug. Your splitter rig is probably a stereo headphone cable. So, the way it’s (not) working sounds about right.
Regards,
Wayne A. Pflughaupt
Tried the video twice and is probably my security software....
RedCharles
WaynePflughaupt
WaynePflughaupt
That splits a stereo 3.5 mm jack. As I stated, the output jack on the Rolls is 1/4" mono.
Regards,
Wayne A. Pflughaupt
RedCharles
So the problem is with the Rolls being what it is. And a different Y cord won't fix this.
So stereo isn't actually necessary? I still don't know what the gear is but a lot of home gear doesn't accommodate mono input.
To use two mics for stereo you don't need a splitter cable. That is NOT the way it is done. Each mic has to be connected to its own preamp and then power amp, or the input of an integrated PA amp. Normally a mixer is involved and you can assign the mic to either left or right channels or pan them anywhere in between.
If the amp is High Z then you need high Z inputs. The best mics are balanced and low Z requiring a low Z balanced input.
RedCharles
Ok, I can fix it with a cable. Thank you.
No, not with mics you can"t. You need a mixer with both channels panned center.
The only other option is to feed each mic though a buffer amp and then blend them. The easiest solution is a mixer with pan facility.
WaynePflughaupt
WaynePflughaupt
I just noticed that you’re “combining” two signals, not “splitting.” As TLS mentioned, that’s not going to work well. What’s the point of combining two mics to do what a single one would do???
Regards,
Wayne A. Pflughaupt
BMXTRIX
BMXTRIX
So many answers...
On the cheap, this is what you need:
https://www.monoprice.com/product?p_id=7128&gclid=Cj0KCQjwitPnBRCQARIsAA5n84kX3j-pZmHphV15YY4r2mZMLTflNwg6fnt_zzbx_c_JpsUT9zpA54IaAgb2EALw_wcB#QuestionsandAnswers
It will take your single channel (tip/ring) mono output and split it to the left and right stereo unbalanced connections which is what you are working with.
As you move on, and get more serious, you can use mixing software on the PC, or a USB mixing board, to take in a single balanced microphone input and share it properly across two channels. Or you can take in two balanced microphones, like you have, and record in stereo, assigning one mic channel to the left, and the other one to the right.
I think almost all live studio work is recorded mono, then remixed into stereo with specific sounds, or levels, feeding one speaker more than an another as desired.
RedCharles
Ya, I'm gathering that what I did, no one does.
