Two ELAC S12EQ vs VTF-15H MK2
john20182050
Right now, I have single HSU vtf-3mk5hp. I want to upgrade.
I'm thinking either ger Two ELAC S12EQ vs two VTF-15H MK2. Which is better? Or any other choices? Budget $2500. Or getting single SVS PB16-Ultra worth?
shadyJ
Speaker of the House
Staff member
No contest, two VTF15h MK2s would wreck to S12EQs. Hell, one VTF15h mk2 would have a major advantage in output and extension over two S12EQs. A PB16-Ultra could match two VTF15h mk2s on deep bass, but not in midbass. It's a very nice sub though.
john20182050
Is there anything better at a similar price of VTF-15H MK2?
shadyJ
Staff member
Depends on what you mean by "better." In my opinion the VTF15h mk2 is a pretty well-rounded subwoofer. The only other ones I would even consider around the same ballpark pricing are the Monoprice Monolith 15" THX Ultra and Rythmik FV15HP. There is also the Outlaw Audio Ultra-X13 for a bit more. The SVS PC12-Ultra probably isn't bad either.
snakeeyes
What don’t you like about the VTF3? You don’t want to add another VTF3? What is the size of the space in cubic feet?
Also if I was looking at HSU VTF15 and Rythmik FV15HP, I would also consider the Rythmik FVX15.
