So, I have an SVS SB-1000 Pro, and a smaller Mission MS-200 10". My Denon AVR has only single channel, parallel subwoofer outputs. I am constrained in my sub placement (WAF), but the SVS is between mains, the other is opposite wall/right side of listening position.
Is there a process where I can utilize both these subs effectively? I am trying to think of a process; perhaps I REW the SVS, then again with the MS-200, then let Audyssey have a got at then together? Is there an option that would work? Only the SVS can be tweaked internally, the MS-200 only has a phase invert switch. I don't want to have them cancelling each other out out of phase or something, but have a good suckout at 105Hz I'd like to fix. Or, is a 2 channel DSP my only option?
