Two channel A/V setup?
Pugsly
I'm new here and don't understand a lot of what is said, but would like some help. I run a strictly two channel system (I just don't like all those speakers all over the room and don't want to re-model my house to install them in-wall or in-ceiling)with Dynaudio 3 way towers with a two channel Marantz integrated ampPM 8006, but it doesn't have inputs for A/V items (HDMI). All the A/V recievers I see have loads of channels. I keep thinking there must be something out there that will support both my turntable and high def TV. Also my optical cable keeps falling out of the port causing me to have to pull everything out and re-install it. Seems super flimsy - it that just the norm? Thanks for any help.
Eppie
Eppie
We had someone ask a similar question recently and one receiver mentioned was the Marantz NR1200. It has both phono and HDMI inputs and 3 other RCA connections and has subwoofer outs to add a managed sub. Similar power to your PM8006. If that's not in your price range or unavailable there are likely other options. You could also go 5.1 and not use the rear and center channels.
No, the optical cable should not fall out. The locking tab is probably broken. If it's the jack, a couple pieces of masking tape or electrical tape will suffice. If it's the plug a new cable may be in order.
L
Leemix
An AVR may seem like overkill with lots of channels but the power supply is shared so when only using 2 channels they will have access to a lot more “juice”. An AVR will also give you more HDMI and other inputs if needed and good bass management if you use or consider a sub. Its an option to consider but there are some 2ch integrated receivers with HDMI now but often just the one output to connect to the TV and use the AudioReturnChannel(ARC or newer eARC).
What is best and sounds best to you i dont know.
BMXTRIX
BMXTRIX
AV receivers are designed to cover as many people as possible. So, your typical 5.1 or 7.1 receiver is actually capable of playing back audio and video in setups that include your setup of a 2.0 system (2 main speakers, no subwoofer). In the settings of the receiver you just tell it that you don't have a center speaker, any surround speakers, or a subwoofer.
This is common across really inexpensive AV receivers all the way up to top of the line models.
Be aware that having a proper 'phono' input on receivers these days is becoming less and less common. So, if that's a feature you want, just look for a model which includes a phono input on it.
So a model like this will work just fine:
There are loads more out there with similar or lower price points which will work great.
You can even go to a lower price point on the receiver if you pick up a separate phono to line level amplifier. This is your call.
sterling shoote
Here's your answer: Marantz NR1200 Receiver
Swerd
Swerd
The Denon DRA-800H seems have what you're looking for, and it costs less than the Marantz NR1200.
