Tweeters, tweeters, and tweeters
Z
Ziptree
Hi all, I'm out to build myself a pair of home speakers, Three-way bass reflex. I've dabbled in the past, read a few books, getting the whole jist of the thing. The tweeters are giving me a bit of indegestion. I've nailed it down to either soft domes or the new ribbon style. I know this may cause a debate but what type, in general, sound the best, clearest, most natural, that kinda thing. With all the different ones out there it's almost a guess.
Also if anybody could point me to a formula to figure out the volume of a trapiziodal enclosure /_\ I would appreciate it.
sts9fan
sts9fan
gotta love google
:) volume I think as far as the tweeters are concered you should go to a store and listen to see which ones you prefer.
Swerd
Swerd
There are quite a few good tweeters available in several price ranges. I have heard and like these: Soft dome models that cost about $30 apiece are the Morel MDT-20 and the Seas 27TFFC (Seas makes quite a few different tweeters many of which are probably good, but I've heard the 27TFFC). The Vifa D25AG-35 is a good aluminum tweeter, about $32. The only the ribbon I've heard is the Bohlender Graebener Neo3-PDR about $44 each. For about $60 each there is the Morel MDT-30. Finally the best I've heard, and the highest price, is the Hiquiphon OW-1 at $90 apiece.
Choose your tweeter after you know what freq will be your mid-to-tweet crossover point. Choose a tweet whose resonance frequency (Fs) is at least 3 times lower than your crossover frequency. This is a bigger issue for a 2-way speaker than for a 3-way.
Hope this helps. What else is going in to your 3-way?
Rip Van Woofer
Rip Van Woofer
See tweeter tests galore at this site by a knowledgable speaker builder. You'll not only get objective quality measurements but ideas on crossover frequencies to use by studying the graphs.
Ribbons vs. domes? As is so often the case, it's the implementation not the underlying principle that determines quality. There are good and not so good of each.
Z
Ziptree
Well I figure I would go with Morel MDM-55 midrange and Dayton ST385-8 15" or ST305-8 12". The mid goes from 500 to 6500 Hz. The 15" woofer goes up to 1000 and the 12" goes to 2000Hz. I'm thinking I'd be better off with the 12" and crossover around 1200. I won't need a handtruck to move it either.
Swerd
Swerd
Tweeter selection may be the least of your problems. Before you proceed, forget the claim of a frequency response of 27-2000 Hz for that Dayton 12" woofer, and have a look at the frequency response curve. Pay close attention to the region between 700 and 3000 Hz where the worst of the cone breakup noise is. If you center your crossover at 1200 Hz, you’ll be right in the middle of that. Your woofer-mid crossover must be able to filter that out. There are several ways to do that:
1) Choose a lower crossover point, about 300-400 Hz (no higher than 500 Hz) that puts your crossover at least one octave below the beginning of the breakup noise.
2) Use crossover with a steep roll off slope such as a 4th order crossover that rolls off 24 dB/octave.
3) Use a different woofer that allows a higher crossover point. A 10" or 8" woofer might be able give you that and still produce plenty of bass.
Do the same for the Morel midrange, forget the claimed frequency response of 500-6500 Hz, and look at the frequency response curve. While there is no breakup noise on the high end (that's good), the response at 500 Hz it is about 5 dB lower than across the plateau beginning at 1500 and ending about 6000 Hz. Above 6000 Hz the response falls rapidly at about 25 dB/octave. To get the best response from the mid, I'd guess that woofer-mid should be crossed at about 1500 Hz. Now you see the problem. While that Dayton 12" is a decent woofer, there is no way it can be combined with that Morel mid without having a lot of breakup noise from the woofer or a large dip in response because the mid can't go low enough.
Ziptree, is this is your first DIY speaker? I really don't want to pour cold water on your enthusiasm, but I strongly recommend that you find some tried and tested plans for a DIY 3-way. There are quite a few available on the internet that have been designed by experienced DIY designer who have tested their designs with computer design software and with acoustic measurements of the speaker. Look at it this way, if you were starting out as a cook, would you invent a new recipe on your first effort or would you follow a tried and tested recipe from a cookbook? Just because you can choose among all the numerous speakers available through Madisound, Parts Express, or some other vendor doesn't mean you know how to design a good crossover. Trust me, I’ve been there. A good crossover can make even cheap drivers sound good, and a poor crossover can make expensive drivers a disappointing waste of money.
If you are interested in building 3-way speakers, have a look at these two designs:
http://www.*****************/projectshowcase/jubilee/index.htm
http://murphyblaster.com/content.php?f=MBOW1_3-WAY.html
I haven't heard the 1st one (the Jubilee), but the designer is widely respected. For some reason that link doesn't work. The Jubilee can be found at the Parts Express project showcase website (or substitute "parts-express.com" for all the stars and leave out the hyphen after parts). Better yet, Google on Jubilees and Parts Express. I've heard the MBOW1 3-way and it is excellent. While you are at the Murphyblaster web site you should read about the MBOW1 2-way and its less expensive cousins the MB20 and MB27. They all can easily be converted into the 3-way. I've built the MB20 and love it. There are plenty more designs out there, maybe someone else can suggest some.
K
Kiwi
Mate , dont panic , give it a go . I read all the you cant do its and for my first speaker project decided on a twin woofer 3 way which according to the know it alls would be inviting certain disaster . I have only made one change to the original crossover design and am more than happy with the result.
My 2c for what its worth is to get a good midrange driver that will go down to say 60hz and up to 3000hz ( I used the peerless CSX ) this will do a lot of the work , cross the base woofer over early at say 250 hz with a soft 6Db per octave simple X over. Use a more agressive X over (3rd order ) for the Mid tweeter at say 2500hz and a series notch filter on the tweeter and an impedence compensation (zobel) filter on the mid.
Use a 1 inch soft dome tweeter because they just sound good and not to bright. Build your cabinet right and you will be a happy camper.
Its not that hard if you have a good basic understanding of what you are doing and if you do get it wrong its easy to tweak the X over
Dave
