Hi there
I'm new to the forum. Thanks in advance for checking my post and (hopefully) helping me out
I have a pair of NAD 804 loudspeakers and i've buggered the tweeter in one of them with some buggy audio production software sending a burst of digital noise through them which burnt out one of the coils
. I can't find any info on those speakers or components at all, but the tweeters seem to match these tymphany/peerless tweeters in both part number and look: www . tymphany . com / 811815. I've copied the specs below to make it easier for you as i cant post a link.
Is anyone able to recommend a readily available similarly specced tweeter to replace the one in each unit, will I run into crossover compatibility problems if i do this, or am i better off taking the tweeter for repair (wherever that might be...)?
I'm not terribly au fait with the electronics in a loudspeaker (particularly crossovers) so be nice, however i'm a quick learner and keen to make this work! If you are just able to recommend some decent brands and a good online store i'm quite happy to look for the right product myself. If you need any more info from me i'll do my best, and I'm in the UK if this makes a difference for ordering parts.
Thanks very much,
Ferg
Specs
Electrical Data
Nominal Impedance Zn 8 ohm
Minimum Impedance Zmin 5.9 ohm
Maximum Impedance Zo 30.5 ohm
DC Resistance Re 5.5 ohm
Voice Coil Inductance Le 0.1 mH
TS Parameters
Resonance Frequency fs 860 Hz
Mechanical Q factor QMS 4.31
Electrical Q factor QES 0.94
Total Q factor Qts 0.77
Force Factor Bl 3.5 Tm
Mechanical Resistance Rms 0.48 Kg/s
Moving Mass Mms 0.038 g
Suspension Compliance Cms 0.09 mm/N
Effective cone diameter D 2.8 cm
Effective Piston Area sd 6.2 cm^2
Sensitivity 2.83V/1m 92 dB
Power Handling
Long-term Max Power IEC 18.3 100 W
Voice Coil and Magnet Parameters
Voice Coil Diameter 26 mm
Voice Coil Height 1.8 mm
Voice Coil Layers 2
Height of the Gap 2.5 mm
Flux density of gap 1.5 mWb
Total Useful Flux 0.3 mWb
Diameter of Magnet 72 mm
Height of Magnet 15 mm
Weight of Magnet 0.24 Kg
Frequency
