arkight
I need some help i am looking for a tv/tuner card i want one with 2 inputs one for cable and the other for over the air HD via and anttenia can i do this with one card or will it be cheaper to do with 2 cards any help is apprecieated.
jinjuku
jinjuku
Moderator
I would look at the HD HomeRun. It is designed to do what you are describing.
Keep in mind that with cable you will need to make sure your provider doesn't encrypt everything. The technical term is Clear QAM. PPV and Premium channels will be encrypted.
You could look at solutions that are M-OCUR (Cable Card) based.
What is your budget?
What is your OS and Media Center?
