Hi,
I have a fairly simple problem in concept, but I'm not sure what device to buy to fix it, although I can think of at least 1.
Anyway, the situation is pretty straightforward. I have a TV that takes a coax cable from the wall for basic cable. The TV just so happens to have NO outputs. My stereo takes an RCA audio input. So, the TV is making things difficult since it has no way of outputting the RCA to the stereo.
Anyway, it's pretty clear to me that the solution to this has to involve sending the coaxial cable signal from the wall into some sort of device which then outputs either coax or RCA to the TV, and also outputs RCA audio for the stereo. The main issue is I don't know what this device would be called or if it even exists.
The closest thing I can find is a Digital TV Tuner Converter Box, which I'm sure would work, but it does much more than I need it to do. I just need a box that will tune the signal and pass on the two outputs (video to TV, audio to stereo), not the whole conversion thing.
Anyway, does anyone have any thoughts on a device that would get this done?
Thanks for your time.
~David
